Syncing problems
As a DJ my honest opinion about Djay Pro. The software has unresolved glitches. The most noticeable one for me is the syncing of tracks together that causes it
to skip it’s placements. This would honestly be the strangest software I have ever used. Because of this malfunction, I can’t use it. This should have been the first fit on Algoriddim’s list. If they’re any solution for this please feel free to address. I’m not using it until they’re a fit and if my yearly subscription ends I will not have any reason to renew. Thanks
Hi @Victor_Pickett, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Hardware Firmware Version:
Can you please also try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
