System set up in what order
Hi. I’m a noob.
What is the best way to start and connect your hardware to the software and in what order.
Do I turn on my external mixer then speakers then sub then connect to my MacBook with the Dj app open .
Or doesn’t it matter.
Please provide some information on the equipment you’re using.
What mixer? What speakers? What sub? Makes and models.
A&H PX5
2 A&H K2s
Makie cbt 8
Makie cbt 3
Makie cbt 8 sub
MacBook Pro
Evermix 4 into iPad Pro
Dj pro 5.1
No such thing as Mackie CBT. I’ll assume you mean CR8-XBT, CR8S-XBT etc.
The recommended order when turning on is source → destination, so laptop first, mixer second, speakers last. Turning off is in the reverse order.
Basically you don’t want power clicks & thumps getting to the speakers, so they’re on last/off first.
So have the multiport usb connected to the Mac and app running then turn on/off in the order you’ve recommended.
Hi @Daveworzel, please also refer to the attached FAQ regarding connecting an external mixer to djay for macOS. Also, thanks to @PKtheDJ for the info regarding the connection sequence to the sound system. Spot on!
