Is it possible to activate / deactivate Tempo Detection on a per song level? This would be awesome because there are a few songs that stay the same tempo but djay pro changes the tempo in a section that doesn’t need it. So it would be nice to just deactivate the tcd option on those songs but leave it on for the other tracks.
Hi @megaman24, I’m not at my computer right now, but this is what the options look like on iOS.
- You can turn tempo change detection between Automatic (Dynamic BPM) or Off (Straight BPM) for all songs in the djay Settings>Library
- You can also do this on a per song basis via the Edit BPM dropdown menu.
Awesome! Found it under the tools bar. Thanks as always @Slak_Jaw
You’re welcome @megaman24
