The tempo sync isn’t always accurate. I have tracks that I created and Djay doesn’t always calculate the tempo correctly. It would be nice to have an option to input tempos yourself.
All my tracks are already analysed using Traktor Pro 2. I don’t need Djay to analyse the BPM.
What I’d actually like is to have the option for Djay to use the pre-existing BPM meta-info where it’s available.
Djay’s BPM analysis is not accurate, and while this is the case we really need to be able to enter the BPM manually as an option also.
Manual set is def needed as tap is no accurate
