Can you please add two options to the preferences:
Tempo reset (on deck load)
Key lock reset (on deck load)
I want to turn off them both!!!
Why i should move the tempo slider to the last position every time i load a track? Most tracks are pritty same BPM, so i use about +3.0% tempo, but I dont want to ajust it allways.
Same about key lock.
Thank you.
