Hi there!
Is there any way to tempo sync effects in Djay Pro AI?
Like if I want a 1/2 note delay for example? I can only see the continuous slider below the effect.
Cheers.
Hi there!
Cheers.
At the moment FX are automatically synced to the Master BPM value but this tempo is not adjustable from the FX.
What you suggest is kind of “emulated” according whit the dry/wet fx parameter, in some fxs.
For example, in echo the wetter the fx, the shorter the delays.
