the app is very laggy
hello
I installed the app and it’s very very laggy
if I want to search a song and scroll , it’s very laggy
if I want to hear a song, the song is very laggy
what is going on with this app???
Hi @bayonetta04,
Thanks for asking in our community.
Could you please tell us more about your audio system? Are you using a Bluetooth speaker? Note that playing music through Bluetooth adds latency to your audio. We recommend using Bluetooth with djay’s Automix feature.
If this is not the case, could you please tell us:
  • What device do you have?
  • What Android version are you currently running?
  • What djay version are you using?
Cheers,G
The program is super resource heavy. If you’re on a Mac, go to Applications/djayProAI right click the app and click Get Info. Select open in Low Resolution Mode and relaunch the application. This solved alot of issues and my system is pretty beefy. Not sure if its the same for Windows but this is the best fix until they can figure stuff out. The interface wont be as “High Def” but I don’t really care as long as it functions and doesnt crash. Hope this helps
