The End of The Numark iDJ Pro Trapped in Obsolescence
  • Device model Apple iPad 2020
  • Version of operating system macOS 26.6.1
  • Version of djay 5.6.8
  • Hardware/controllers used IDJ Pro
  • Hardware firmware version 1.3.9
A Little Bit of My Story
After eight years as a resident DJ across two nightclubs in Brazil, good music became a way of life for me. At work, in the car, and especially at home, I’m always setting the vibe for my family. We love hosting, so dinner at our house frequently evolves into a full-on dance party.
To recreate my favorite sets on a budget, I searched for the ultimate cost-effective setup and landed on a Numark iDJ Pro paired with a 2nd-gen iPad. If you aren’t familiar with it, the iDJ Pro lets you slide an iPad right into the center console—voilà. Connected to Spotify, my entire library was ready to mix. It looked sharp and sounded incredible. Guests were constantly asking about this self-contained controller that offered pro-level features like XLR outputs, AUX, and mic inputs without needing a laptop.
When Algoriddim dropped support for early iPads in 2018, I modified the unit with an original Apple 30-pin to Lightning adapter to fit an iPad Air 2. It worked like a charm. By 2024, wanting to eliminate a bit of latency, I upgraded to a much newer iPad, keeping my dream combination of djay Pro software and bulletproof hardware alive.
That’s when the trouble started. A recent Apple update locked newer iPads to a 48 kHz sampling rate. Because the iDJ Pro is fixed at 44.1 kHz, the audio went to pieces—plagued by severe cracking, particularly in the bass line. Knowing Apple wouldn’t push a fix for my setup, I tried retrofitting my old iPad Air 2 back into the unit. To my frustration, I hit another wall: Spotify now blocks logins on older iOS browsers due to outdated security standards.
A New Sad Reality, The Triple-Lock Bottleneck of the Numark iDJ Pro
For anyone still holding on to the Numark iDJ Pro hoping to keep it alive with streaming services like Spotify, TIDAL, Apple Music, or SoundCloud via djay, the controller has effectively hit a total dead end. It isn’t just about an aging dock port—it’s a confluence of three distinct compatibility issues:
1. The Streaming / Web-Auth Lockout (Older iOS Devices)
Legacy devices like the iPad Air 2 (capped at iOS 12) run clean 44.1kHz audio through the 30-pin/Lightning bus. However, web-based OAuth logins (which DJ apps use to sign into streaming platforms) require modern WebKit/Safari security protocols. iOS 12 can no longer complete these handshakes, rendering online streaming impossible on older hardware.
2. The 48kHz / 44.1kHz Sample Rate Mismatch (Newer iPads)
Bypassing the cradle with a 30-pin extension cable to run a modern iPad (iPadOS 14+) creates a severe hardware conflict:
  • The iPad Clock: Modern iPadOS hardware locks system audio output to a fixed 48kHz sample rate.
  • The Controller Clock: The iDJ Pro’s internal sound card is hardware-locked to a fixed 44.1kHz clock rate.
  • The Result: Because the legacy sound card cannot auto-resample or match the 48kHz stream coming from the modern iPad, audio plays back severely distorted, producing digital jitter and crackling.
3. Zero Cross-Platform Driver Support
Because the controller relies entirely on Apple’s proprietary iOS Core MIDI and Lightning audio architecture, it cannot be routed to a PC, Mac, or Android tablet. There are no standalone USB host ports or third-party audio drivers for Windows/Android.
The Final Verdict
Unless you use an iOS 12-era iPad solely for playing locally stored, pre-downloaded MP3/AAC files, the iDJ Pro is officially obsolete for modern live-streaming DJ setups. Any attempt to use modern iOS hardware will conflict with the audio engine, and any attempt to use older hardware breaks modern web authentication.
Ultimately the end of a FANTASTIC solution for mobile DJs (and not so mobile ones).
What’s your opinion?
My opinion.
Tech moves on and eventually you have to think about upgrading. An iOS 12 iPad is restricted in far more ways than that.
Controllers have also moved on since then. It’s harsh but it is what it is, you want a lifelong DJ device, buy a pair of 1210s as they are the only mainstain in our world.
Hi @Marcello_Silva, thanks for sharing this. Sorry to hear that you have to retire this setup. Sounds like you’ve really tried almost everything to keep it going. I still have my original Vestax VCI-400 that I bought back in 2011. Also, built like a tank and still functioning. Even though it still works, I haven’t used it in years mainly because it lacks some of the modern feature improvements like RGB pads, more than 4 pads modes.
One option for you that might be worth considering is an iOS compatible external audio interface. Then you simply use the iDJ Pro as a MIDI controller and route your audio through the external interface. This would be a more complex setup, but could allow you to continue using your existing hardware with a modern iPad. Then again, it probably makes more sense to upgrade to a modern device with a built-in audio interface.
Hi Stu, you’re absolutely right about tech moving on, but in my opinion, hardware and software companies should still give everyday users a fair chance to keep working gear running. When you buy into a brand, you expect true ownership of that hardware.
Imagine receiving an invoice from Technics because you hit 100,000 hours on a turntable, followed by an email saying your second pickup will stop working next month! (By the way, my own 1200s are 35 years old and still run like new.)
If you’ve never seen the iDJ Pro in action, the real beauty was not needing a laptop (which I personally hate having in a setup). Having a sleek, self-contained controller paired with Algoriddim djay and direct access to a vast streaming library made it the ultimate hassle-free rig for entertaining friends.
I actually have other gear at home (Denon, Stanton), but that’s beside the point. It’s not about refusing to upgrade—it’s just frustrating when perfectly functional, solid hardware gets bricked purely by software decisions. Planned obsolescence is a sad reality.
Thanks for jumping into the thread and for the shoutout to the 1210s—you can never go wrong with a classic!
Thanks for sharing your story and for the creative suggestion! The Vestax VCI-400 really was built like a tank—hard to beat that era of build quality, I love it.
I actually thought about using an external iOS audio interface to keep the iDJ Pro alive strictly as a MIDI controller, but like you said, adding extra dongles, cables, and routing complexity defeats the purpose of why I loved the setup in the first place: the clean, self-contained workflow.
At this point, I think moving to a modern device with a built-in interface is the most logical route. I’m currently looking closely at the Reloop Beatpad 2, Mixon 4, or even stepping up to the Mixon 8 Pro. They keep that great Algoriddim djay integration while giving me modern features and performance pads without the hassle. Thanks again for the solid advice!
I think your main problem here is (I believe) Numark have been taken over since that device came out, so there is little commercial appetite for InMusic to carry on supporting I guess, as they had no involvement with the device design and marketing.
I had the exact same problem with my Rane SL3, which I’ve had to replace with the Reloop Flux.
Honest opinion, I would seriously be looking at an Engine powered device like the SC-Live 4 or the Rane System One. Or even the Prime Go+ if you seek portability. They are extremely powerful standalone devices that receive regular updates and have most streaming platforms built in. Or if you’re wanting on device stem processing, wait for the next generation of Engine devices to launch.
You’re welcome @Marcello_Silva. I’ve personally owned a Reloop Mixtour, Reloop Ready, Mixon 8 Pro and now a Mixtour Pro. I’m very happy with all of them and their integration with djay.
Hi Stu,Thanks for the background on Numark/InMusic—that context makes a ton of sense regarding why support faded out. Appreciate you sharing your experience with the SL3 and Flux as well!
Those Engine OS standalones (SC Live 4, Prime Go+) are fantastic pieces of gear, but since I’m so hooked on Algoriddim djay Pro, I want to stay tied to that software. That’s why I’m leaning toward picking up a Reloop Beatpad 2, Mixon 4, or Mixon 8 Pro to get proper modern hardware support without changing my preferred software workflow.
Thanks again for jumping in with those ideas and recommendations, man!
The Mixon 8 pro looks a fantastic machine tbh, with an iPad slot too, and one that should remain supported for a long time due to not being reliant on Apple keeping their design the same.
