Hi @Oranium, a quick fix could be to navigate to the djay Settings>General>SONG LOADING and turn ON Reset EQ, FX, Tempo. This should disable any FX on deck 2 when you load a new song.
In addition to that, djay offers several different FX options, so looking through each of these you can likely locate the specific issue. The 3 main FX options in djay are Manual, Instant and Pad.
In addition to those, we have Crossfader FX, which are accessible from the pop-up menu to the right of the crossfader.
