The Gemini PMX-10 is a 2-channel DJ mixer
The Gemini PMX-10 is a 2-channel DJ mixer that also functions as a MIDI controller and audio interface.
Anyone know if it available in DJay Pro, controller list.
Im thinking buy one and to mapping, like i did with my MK3 -X1
Look interesting with all midi boutons.
It’s very easy to check yourself. Top right press Algoriddim logo. Then top left and press 3 lines and dj gear. From there you can check to see on what platform each piece of gear is supported. If not supported but is midi mappable you may be able to Map yourself. If not class compliant it won’t work with iOS as the mixer will need additional drivers to work. Hope that helps.
Thanks for that @Dysfunk_DJ
