macbook pro 2.3ghz 8 core
sonoma 14.3.1
djay pro 5.3
ddj400
Hi. When searching for tags in the Label column, it only works within the Playlist — not across your Collection like it does for other columns (Composer, Grouping, etc.).**
For example, if the ‘Search Playlist’ icon is selected in the search box, you’ll see results from the current playlist. But if you turn it off to search your Collection, nothing comes up — the second list is empty.
Hi @Donn, thanks for the info. I wasn’t able to replicate this. Can you please try to capture a short video of the issue and upload it here? Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
