Hey Slak_Jaw
Since you guys are in the giving mood, can we get the old bigger cue markers?
The new ones are pretty small…
djerniefromjersey
Hey Slak_Jaw
djerniefromjersey
Hey,
I have uninstalled and re - downloaded several times with the same error message as your screenshot. Any help would be appreciated.
Same here just encountered same issue about to go live on air and wont open for love nor money just crashes
Mac mini M2
Sonoma 14.3
You have to update your laptop to the latest software otherwise the upgrade won’t work. That’s what happened for me, hope this helps
Ok so i am using dj pro version 5.0.3 and a macbook pro that is a 13 inch M1 2020 running Sonoma 14.0.
I have all the music downloaded.
I keep getting random freezes during songs. The really scary part is that it was during drag performances of 22 different queens, all of them giving their all and the were getting progressively more annoyed with me the DJ.
Please suggest a fix. I dont want to get beat up by a squad a fabulous queens. Please help!!!
“Freezing the music on 22 queens would be a scary scenario,”
When the song freezes, are you able to press play and it starts again or do you have to shut down the app and re start?
Are you using a controller or just the app within your MBP?
I will try closing any background apps next time. Not that I had many running that evening. Internet is actually wired in but I don’t really see how iCloud would be taking up that much processing if nothing else is running in the background. Is that really an issue? I literally have had all kind of apps running in the background I never had it freeze before. Do you know of any other possible reasons?
No, i dont have to push play again. It starts on its own but the pause is terrifying. I am using a pioneer DDJ 200 controller.
An iCloud backup of your entire laptop during DJing could easily cause issues.
That’s different to the issue i was having.
My controller (Rane One) would just stop playing and pressing play would re start it…
I now perform a hard reset on my iPad before each set and close all apps…
It seems to have done the trick
