Ive seen the upgrade ideas but imo there are 3 I would like to see -
1 - A set/lock switch for the RGB cue points - if you cue up every song ready its too easy to press the wrong button - This must be easy to programme
2 - A portrait mode for 1 deck full screen - Allows 2 iPads with a normal mixer & headphones - It works on the nonHD version - This is probably harder than it sounds but has to be important.
3 - If the Vinyl grooves could reflect the BPM/Sound on the spinning record that would be awesome - Hard to porgramme & not really necessary if no.1 is done.
Reply if u agree 123 - Yes Yes
