Are u running on the ios version? I lifted an amx but cant seem to route the audio out - 7"serato timecode works fine. Any help is very much appreciated
@Old_Man_Ratchet and @Joachim have you seen this video? I realize it’s a different mixer than yours, but I suspect it will be helpful none the less.
Also there are some DVS setup guides for iOS and MacOS
Yes i have, this is for the S7 , the catch is you still need to hook it up to change the input from phono to line each time you do a restart.
Appreciate the guide. In my case, DVS and calibration works on serato 7" with the akai amx. Its just that i cant seem to route any audio out thru master and pre cueing. The only time any audio is heard is when we switch the output to ipad speakers.
Also tried using traktor split cables but to no avail.
Update: this set up works like a charm on DJ Player Pro.
Looks great. I literally just want the “set grid start” issue fixed.
Update , i got this to work
