Our team is thrilled to announce the next major update to djay Pro AI for macOS and iOS, now available on the App Store. We’ve packed this update full of some of your most requested features, including the long-awaited addition of DVS.
Now, all you need is your iPhone, iPad, or Mac with a PRO subscription to djay Pro AI, compatible timecode vinyl records, properly calibrated turntables, and your DVS-compatible mixer, and you’re ready to go!
We’ve been listening to your feedback and suggestions, and working closely with some of the world’s top DJs, to carefully adapt djay’s user interface to ideally complement any connected hardware and provide a unique blend of tactile and touch-based control. Moreover, djay’s audio engine has been fine tuned for digital vinyl control to offer the tightest scratching, most accurate time-stretching, and lowest latency possible.
Watch as world champion turntablist DJ Angelo walks us through the new DVS features in djay:
And, there’s more!
We are also excited to introduce our new DVS format, Neural Mix™ Vinyl: offering isolated stems for any song right on the B-side of the control vinyl. With the official djay Control Vinyl, you can simply drop the needle of the analog turntable onto one of three distinct tracks on the physical record to play either the original song, its instrumental version, or the acapella. See it in action with DJ Angelo:
Other NEW features and updates included in this major update to djay Pro AI:
- Advanced DVS options: including Internal, Relative, Absolute modes, Muted/Gated Cue, Seamless calibration, Neural Mix Vinyl settings for B-Side (Instrumental, Acapella vs. Drums, Melodic)
- DVS Auto Setup and Calibration: support for official djay Control Vinyl + smart auto calibration, supports standard time code DVS systems that use a control tone of 1kHz (which the vast majority of DVS systems nowadays do)
Plug-and-Play DVS integration through popular performance mixers, including:
- Reloop ELITE (Mac+iOS)
- Pioneer DJ DJM-S3 (Mac)
- Pioneer DJ DJM-S7 (Mac+iOS)
- Pioneer DJ DJM-S9 (Mac)
- Pioneer DJ DJM-S11 (Mac)
- Allen & Heath Xone:96 (Mac+iOS)
- Allen & Heath Xone:PX5 (Mac+iOS)
- RANE MP2015 (Mac+iOS)
- RANE SEVENTY (Mac+iOS)
- Denon X1850 Prime (Mac+iOS)
- Redesigned user interface
- Hardware UI: djay automatically switches to a new user interface developed and finely tuned with professional DJs when connected to DJ hardware controllers and DVS
- Improved layout for cue points, loops, and effects
- New audio effects: includes brand new Instant FX and a full suite of stunning new AI based audio effects that are rendered in real time
- Pitch cue/tone play: Use pitch-altered cue points to create new musical moments from your tracks. You can choose from a variety of auto-generated scales including chromatic, minor, major, and the blues scale.
- Cue point color editing: Change the color of your cue pads in both software and hardware to suit your workflow. Cue point colors for tracks are seamlessly synchronized across djay on Mac, iPad, and iPhone via the cloud.
- Advanced Time Stretching: Change the tempo of a song without affecting its pitch using the enhanced industry leading élastique Pro V3 by zplane
- Enhanced Quantize options with high precision quantization for loops and cue points
- Booth output: Add booth volume control on supported hardware
- Microphone input: Along with macOS, iOS devices now support microphone input
Enhanced Music Library Management
- Streaming playlist editing: Edit and create TIDAL, SoundCloud, Beatport, and Beatsource playlists from within djay
- Track root key color coding: Key tags are color coded for easy visualization
- Numeric key information
- Track information panel (macOS only): Quickly view the track waveform, cue locations, plus essential metadata in the new track info side panel, automatically updates content based on library track selection or active deck
- Related tracks tag (macOS only): Group tracks that go well together by dragging and dropping for quick and easy reminders while you browse track information
- Colored track tags (macOS only): Highlight tracks within your library using eight different colors to help your organization
- Highlight played music: Keep better track of what you’ve already played with library color-coded text
djay Pro AI is available as a free download with the optional PRO subscription to access all content and advanced features across your iPad, iPhone, and Mac devices using the same App Store account.
With all of these innovative and creative possibilities at your fingertips, what would you mix with djay? Let us know! ![]()
Your Algoriddim Team
