I noticed when I play a track in 8B songs I have in 7B or 9B don’t show up as a match. This should be the case right? Now instead it finds songs in 7A which is not a match when playing a song in 8B.
Yes it’s set to fuzzy.
If you don’t want 7A to match with 8B, then you need to turn fuzzy mixing OFF.
Thanks! That made it more clear.
However this will only find matches in the exact same key. I need it to find matches one step up or down as well.
Hmmm, it looks like the only options are fuzzy and exact - which seems to be the problem.
Standard (non fuzzy) matches should be either side of the original key, plus the relative major/minor.
Fuzzy should mean that you basically ignore the letter, so e.g. 9 matches 8 and 10 regardless of A or B.
Thanks for the helpful explanation and for sharing that article @PKtheDJ.
Hi @Johan_Rosenberg, thanks for the information. I’ve sent this to the dev team for further review and consideration.
