The Tempo Slider does what he want
  • Device model: Android redmi Note 12
  • Version of operating system: new Version
  • Version of djay: New version
  • Hardware/controllers used: Hercules DJ Control mix
The Tempo Slider is Not in the Same Level with the Slider Position on the djay app when i am Putting the Tempo at 0 on the Hercules Controller IT Changes to full Speed on the App Automaticly and even when i dont Touch IT on the Controller the Tempo is going Back and Forward in the App . I dont know what that ist and how i can fix IT.
Yes it’s supposed to do that. The new Fluid Beatgrid system detects variation in tempo, and you can see this reflected in the BPM readout. When tracks are synced. you will see the tempo adjust live.
Thats not good enough i hate wen my tempo slider wont control the software till i have to match my hardware tempo slider to d software over and over again nd dat cause my bpm out of syncs unexpectedly that not making sense unlike serato sync nd tempo adjust
