You’re welcome @Bigwig_XL
Nice! update available here in Canada for iOS!
Also I didn’t change from my family plan to individual and I seem to still have access to tidal and neural mix! Woohoo!!
Result that is. Boom
Possibly Algoriddim haven’t quite finished the integration. I guess turning stems back on was the easy bit, but perhaps the check for the DJ Extension is not in place yet.
I’m not sure tbh. On my tidal app it shows tidal+dj integration still. I messaged them about this few weeks back that the family plan should still include dj add on since family members have different logins so should be no reason why you cant add it to a family plan, told them i would happily pay for the integration but not get another individual and force my family to pay their own as doesn’t make sense. Regardless I’m super happy tidal stems are back, using beat source and transferring playlists constantly was not the way to go. Slower loading of playlists and not all tracks available really made it challenging.
I have Tidal with the DJ Extension and still cannot access Neural Mix. Anyone still having issues?
I’m in Texas and still cannot access.
Did you download djay 5.1.5?
Hello, Thanks for the New update
. I Just miss the OFF Line mode with TIDAL. Will you do something for this ?
Me too - I’m honestly not that bothered about stems, but offline locker would be amazing. Is this likely to get implemented? Cos £19 for tidal with offline = very worthwhile, but £19 for Tidal without offline = use Apple and buy the tracks that are available on Tidal but not Apple.
What about OFF Line mode ? Are you working on it ?
We have no news to share about TIDAL offline mode at this time. If that changes, I’ll share info here. Thanks!
iPad 9th Gen, 10.2inch 64Gb
IPadOS 17.4.1
Djay Pro 5.1.6
UK
Still unable to use neural mix. Have checked my subscriptions and everything’s in order. Super frustrating.
Try hard resetting your device. Logging out of Tidal and logging back in.
Thanks for the reply, have just tried this but I’m still getting the message saying “…this feature is currently not available on this platform”
Have you signed in to your djay account? Not sure what else to suggest.
Below my djay account should have your email address if your logged in
Still nothing, unfortunately.
