So I have been using djay pro for a long time now, an when they went from djay 1 an 2 to only 1 platform, an now that it’s tidal an not Spotify, after like 3 or 4 min of playing off tidal, I’ll get this message saying I don’t have streaming privileges for the next 3 min, really ruins my flow on the show
Hi @stx_god,
Sorry to hear about the issue you’ve encountered with TIDAL in djay. So we can take a closer look, could you please tell us the following:
- What device are you currently using?
- Which OS version is running on your device?
- Which djay version are you using?
- Is this a new problem that just started happening recently? If so, did you do any recent updates on your device?
- When you get this message in djay, are you able to at the same time play from the TIDAL app itself without a problem?
Thanks in advance for the additional information.
