Timing issue with Echo Out Effects in DJay
Timing Issue with Echo Out Effects in DJay
I’ve captured an issue on video that I already noticed a while ago for the first time. It’s regarding timing of effects in DJay going from good to imperfect, and I’ve managed to pinpoint it to show you. Note that this may also apply to other effect/stem combinations. Also I’m testing it here on both decks for thoroughness, but the problem seems independent of decks.
Please bear with me and watch the entire video, as the explanation becomes clear by the end.
On each deck, I’ve set up the same effects: “Echo Out” applied to the entire track and “Echo Out” applied to the vocal stem only. Here’s what I observed:
  1. Echo Out on Entire Track and Vocal Stem:
  • The timing is spot-on for both. The effect activates exactly on beat and behaves as expected.
  • Even when activated using my Reloop controller, the timing is as expected.
  1. Inconsistent Behavior:
  • The issue arises after performing a mix. If I’ve used the the track beforehand for some kind of mix, the “Echo Out” on the vocal stem becomes slightly delayed—off the beat and behind the word “place” in my test track.
  • When I tried this effect earlier, without mixing beforehand, it worked correctly.
  1. Potential Cause Identified:
  • While recording this, I may have found the root cause of the issue. It seems tied to whether you already played / mixed a while. This may confuse the internal clock / timing of at least the stem/mix.
Summary:
The timing of the “Echo Out” effect on the vocal stem becomes inconsistent after performing a mix, possibly due to a specific workflow. Restarting the software or controller may temporarily resolve it, but the problem reoccurs. This makes it challenging to mix accurately.
I hope this feedback helps highlight the issue for further attention. Thank you!
==> Again, note that this may also apply to other effect/stem combinations, so please test it thoroughly before introducing a partial bug fix.
BTW: during this demo I had my Main Output mapped to the MacBook Pro Speakers.
Device: MacBook Pro (16", 2019)
Operating system: Apple OS / Sanoma 14.6.1.
Djay version: Djay Pro 5.2.6
Hardware/controllers used: Reloop Mixon 8 Pro
I haven’t heard anything yet, but I hope we can agree that this should be considered a bug, @Slak_Jaw?
Hi @DJ_Big_Blender, sorry I was busy catching up with other users before my holidays and didn’t have time to investigate this one. I’m OOO until Jan 26, but you can submit an official support request from within djay. Please see link below for more details. Thanks.
No problem. I will wait till you are back in the office.
Have fun!
The moment when the timing issue happens in the video there is one thing different: you have the Sync function on.
So my guess is that it has something to do with the FX snapping to the grid or/and Quantize being active.
Hi @delaSarge,
Thank you for taking the time to watch the video and for your keen observation! I almost always work with the Sync function enabled, so in principle, this feature should actually perform at its best in such cases I would say.
It indeed likely has something to do with Snap/Sync/Quantize, but it doesn’t explain to me why the issue only occurs with the effect on stems vocal and not when the effect is applied to the entire deck.
Hi @DJ_Big_Blender,
Thank you for sharing this timing issue with us.
Our teams are currently looking into it, and we should have an answer fairly soon.
By any chance, do you know if this issue was present on djay Pro v5.2.5 (the previous version)?
Hi again!
I cannot tell you for sure, to be honest. However, I started noticing this behavior for the first time one or two months ago. But please don’t hold me to that—I can’t say for certain which version it started.
Hi @DJ_Big_Blender,
I’m happy to share that our engineering team found the root of the issue and is working on the next steps to address it in a timely manner.
Again, your video was extremely helpful in the testing process so thank you!
@Slak_Jaw: Any news about this?
Hi @DJ_Big_Blender, I believe you are already discussing this topic with Nathaniel.
Hi @DJ_Big_Blender,
As @Slak_Jaw stated (thank you, by the way), our teams are still QA’ing this issue and working towards a solution.
Similar to how I shared in your track stuttering topic, this issue happened to be greater in scale than originally anticipated. However, we are actively working on this and will provide substantial updates as they come in.
Thank you again for your patience.
Hey @NathanielAlgo, @Slak_Jaw,
It’s been quite a while since the last update on the Echo Out timing issue, and I wanted to check in. I know the team identified the root cause back in January, but we haven’t heard anything since.
This issue is still making it difficult to mix accurately with this feauture, especially in live settings. I completely understand that some fixes take time, but it would really help to get an update on where things stand. Has there been any progress? Is a fix in the pipeline? Even a rough timeline would be appreciated.
Thanks for your time and for keeping us in the loop!
Hi @DJ_Big_Blender, I just sent you a DM regarding this. Please check your inbox. Thanks!
Hi @Slak_Jaw,
It seems like the Echo Out timing is still not correct in 5.3. like you can see in this video.
Like you can see in the video, it looks like a problem of the sync. When sync in On, timing is Off.
Did you expect it to be solved or not?
Hi @DJ_Big_Blender, thanks for sharing. Yes, I believe some improvements were made in 5.3. I will pass on your new video and comments to the team.
Hi Algoriddim,
To tell you the truth: I’m honestly surprised that this issue still hasn’t been resolved, even though the root cause was identified back in January.
As shown clearly in this latest video (attached)), the Echo Out timing is still off after one or two records playing (when Sync is enabled). This makes it really unprofessional and unreliable to use fjay in a live setting.
Can we please get a concrete status update? How far along is the fix, and when can we realistically expect it to be resolved?
Do you agree that this part of the 5.4. release notes
Significantly improved key lock latency for scrubbing, beat jumps, and applying Neural Mix routed FX
is also about the issue described in this ticket?
Well I must say it looks like that problems with timing is finally gone…
Thanks for the follow up @DJ_Big_Blender. Yes, this was part of 5.4. I must have missed sharing that here.
