How can I toggle between the four channels in Djay Pro for iPad when using the DDJ-WEGO3? That is, so that I from the controller itself can control and toggle between all four channels. Cheers, Jonas
Hi Lucas,
Yes I understand. What I wonder is if if it would be possible to change which channels on the iPad would be active on the WEGO3, that is toggle between the four making them active on the two channel controller.
Cheers, Jonas
Hi Jonas,
thank you for your post.
Please note that the WeGo 3 is mapped as an 2 channel controller and therefor can’t toggle between the four channels.
Nevertheless you can use the other channels via the iPad.
Not possible presently mate unless Algoriddam change the mapping.
