Toggle Waveforms in Hardware Mode
Hello! I’ve been using DJay with a Reloop Mixtour Pro lately and I absolutely love it. I recently discovered the hardware mode layout and found that it solves almost every visibility issue I had when using the Mixtour with my iPhone. However, I do have one suggestion. When in the standard, non-hardware 4-Deck mode, the Mixtour Pro has a MIDI shortcut for toggling between seeing waveforms and seeing the panes for hot cues etc. This is accomplished by pressing shift + the left neural mix button. In hardware mode, however, this shortcut does nothing despite the general layout between the two modes being similar. I still have the toggle waveforms MIDI command connected to the same two buttons, but it still only works when not in hardware mode. If I could get this same functionality in hardware mode then I really think DJay for iPhone would be a perfect portable-yet-professional setup. Thank you!
Thanks for the feedback @bogdalene. I checked for myself and I see what you mean. I will pass this onto the dev team for consideration. In the meantime, you can enable this view mode via the onscreen controls on the iPhone while in 4 Deck Hardware Mode:
Having a midi option to toggle 2 or 4 hardware deck mode will be super useful.
Thanks for passing this along @Slak_Jaw ! Sidenote, I noticed it looks like your waveforms are horizontal while in 4-Deck hardware mode, while mine are vertical (on iPhone 13 Mini). I’m happy with how it is on mine but I’d love to know how to change the waveform orientation, I can’t seem to find the setting.
You’re welcome @bogdalene. See below regarding horizontal waveform settings.
