English Translation via ChatGPT:
Hello, I bought this application to replace Rekordbox and Virtual DJ, believing it to be the flawless software, but I was completely wrong. I have a gaming laptop Acer Nitro 5, Intel i7 10750h, 16GB of RAM, 512GB, GTX 1660Ti graphics card, previously on Windows 11 but downgraded to Windows 10 due to sound cut-off issues. Today, I am dealing with a new bug on an effect that makes my Numark Scratch mixer bug out.
There is no way to sync the Rekordbox library, nor Serato, and we are forced to install iTunes and redo the playlists from scratch.
Too much autonomy, too much AI, and as a result, many bugs that are not fixed.
ZeroâŠ
Original Post:
Bonjour, jâai achetĂ© cet application pour remplacer Rekordbox et Virtual dj en croyant que câĂ©tait le logiciel sans faille mais je me suis carrĂ©ment plantĂ©. Jâai un pc portable gamer acer nitro 5, Intel i7 10750h, 16go de Ram, 512go, carte graphique gtx 1660Ti, avant sur Windows 11 puis rĂ©trograder pour le Windows 10 car problĂšme de coupure de son. Aujourdâhui je me retrouve avec un nouveau bug sur un effect qui fait buggee ma table de mixage numark scratch.
Pas moyen de synchroniser la bibliothĂšque rekordbox, ni serato, on ai obligĂ© dâinstaller iTunes et de refaire Ă zĂ©ro les playlist,
Trop autonomie, trop de lâia, et rĂ©sultat beaucoup de bug qui ne son pas rĂ©parer.
ZĂ©roâŠ
Hi @Eric_Locloc, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just âiPadâ or âLatest Versionâ. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Hi again @Eric_Locloc, Iâm sorry to hear you are experiencing bugs with djay, can you please try to capture a video of the bugs you are experiencing, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Then I can forward these directly to our engineering team for further review. Thanks!
English Translation:
I found a software to sync playlists, cue points, and loops between multiple programs. Itâs DJCU âDJ Conversion Utility.â Once youâve created your playlists, cue points, and loops on DJay, Serato, Rekordbox, or VDJ, it converts them for the other platforms.
Original Post:
Jâai trouvĂ© un logiciel pour synchroniser les playlists, les cue points et les boucles entre plusieurs logiciels. Câest DJCU âDJ Conversion Utilityâ. A partir du moment oĂč tu as créé tes playlist et tes cue points et boucles sur djay, ou Serato, ou Rekordbox, ou VDJ, il te les transforme pour les autres plateformes.
