Hi @Z1K4LL, welcome to the Community! Sorry to hear you’re experiencing this issue as well. Thanks for sharing the additional info and screenshot.
Hi @Stephen_Carroll and @Z1K4LL, I heard back from our engineering team regarding this. It looks like the Android version of TagLib, which is a 3rd party library we use for reading metadata tags in audio files, does not like UTF-16 encoded tags. Our team is going to investigate options. In the mean time you can convert the affected files to re-encode them using UTF-8. The following ffmpeg command should do the job:
ffmpeg -i “input.mp3” -map 0 -c copy -id3v2_version 4 -write_id3v1 1 “output.mp3”
Hello again @Stephen_Carroll and @Z1K4LL, I’m just following up on my last message from a week ago. Did re-encoding the tracks to UTF-8 solve your issue?
Hello! It’s been another week since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
Hi Slak_Jaw,
Thank you for the tip, i’m not at home , but i’ll try your solution on next week ![]()
Regards
You’re welcome @Z1K4LL. Sounds good!
Thanks for confirming @Stephen_Carroll
OK, the origin of this issue was find, but this isn’t a real solution, is it possible to really solve it inside software code?
Many thanks!!
You’re welcome @Z1K4LL. Thanks for the follow up. Our dev team is investigating potential options.
Many thanks ![]()
You’re welcome
