Is there a way to make Spotify tracks appear in the Dj Pro library in the same order as they do in Spotify?
It seems that they do by default… but, if any of the sort options in Dj Pro are used then I can’t figure out a way of returning back to the manual track ordering I have spent a fair amount of time working out in my Spotify library.
Hope this makes sense - would be interested to know if anyone has figured out a way of doing this
Hey there,
hitting the sort category the first time -> ascending sorting
hitting the sort category the second time -> descending sorting
hitting the sort category the third time -> defaut sorting (playlists like in Spotify app)
Cheers,Lukas E.
I am referring to the title of the column like:
NAME ARTIST TIME BPM KEY etc.
Hope this is helping
Cheers,Lukas E.
Thanks for the reply Lukas, but I’m not quire sure what you mean by ‘hitting the sort category’. Please can you clarify?
