On a new iPad Pro, Djay Pro is not loading on any files. Message says files are drm protected or not available. The files loaded are owned and downloaded. Works fine on iPad 2. Please advise
Hi Ritesh,
were did you purchased the files?
In which format are they in?
Cheers,Lukas E.
