Traktor Kontrol F1 with DJay for AI
I was able to get the MIDI Map for the F1 Traktor Controller. you need to hit Shift+Browse to go into Midi Mode. Then DJay will see it as a midi controller. Now it’s time to map it!
Did you connect the Traktor Kontrol F1 to iPad or to a computer?
The f1 dont have a build in Audio interface. So it will work only as Midi Controller.
Only as a Midi Controller and not very good one in this case. after reviewing the functions, some of the buttons are double assigned. I tried to set up the LOOP functions in it. Those are easy to trigger and the level controls. but thats all it’s really good for. And yes, you will need a computer. I haven’t tried on an IPad yet.
i have an F1, i tried to connect it to an iPad for use with Djay.
I am aware that the F1 has a midi-mode, activated bij pressing browse+shift but unfortunately it is not being detected bij DjayPro on iPad. on the other hand, the F1 is being detected bij DjayPro on a mac or PC. just not on iPad :frowning_face: my best guess is the F1 is not usb-class compliant. therefore Algoriddim cannot fix that
you are correct, it doesn’t work the same. many of the buttons are duplicated with other button in the Traktor system. It took me a while to figure it out but you’ll notice it in the mapping. However, the X1 maps sweet and use it as a mini console for travel.
did you use a USB-C hub to connect to the ipad? I haven’t been able to get it working direct, through a hub or a TB-dock. :frowning:
@Anthony_Ramirez @thedrummingdj
Hey fellas, with Djay 5.3 I’ve been looking for a 4 fader midi controller with 16 buttons. They idea would be for the faders to control stems while 8 pads would be mapped to deck one and the other 8 pads would be mapped to deck two, both to handle fx.
The f1 seems to be the only off the shelf solution. I have a MacBook m4 and an iPad m3.
This thread is dated but would you guys happen to know if the f1 could be mapped as I suggested? Alternatively, maybe share an update on how you use the f1 since the original post (if you are still using it)?
I have and use the F1. I have not been able to get it to work with the iPad (m4 here) but it’s lovely on a pc!
Good to know it would work on my MacBook. I assume you connected the f1 to the iPad with a hub.
I wonder why it doesn’t work with an M4 iPad. I have an Akai lpd8 and it works with Mac and iPad (without a hub) seamlessly.
For a midi controller that came out 15 years ago, I’m struggling to find a good deal on it. $150+ on eBay, plus shipping! :face_with_symbols_on_mouth:
Hi @d.Jaebren, I’m pretty sure this is because the F1 is not USB class compliant. Non class compliant devices currently don’t work with iOS devices.
That’s exactly right. Lots of devices that have their own programming language, like an Ableton Push, these controllers, don’t work. I even tried using an iconnectivitiy device and a H4MIDI by CME as a middle man. Samson made something called a Conspiracy that had LOTS of faders and buttons and stuff. Also, don’t overlook the AKAI https://www.sweetwater.com/store/detail/APCmini2--akai-professional-apc-mini-mk-2-performance-controller-for-ableton-live?mrkgadid=&mrkgcl=28&mrkgen=gpla&mrkgbflag=1&mrkgcat=keys&midi&acctid=21700000001645388&dskeywordid=&lid=58700008695591288&dsproductgroupid=&product_id=APCmini2&prodctry=US&prodlang=en&channel=online&storeid=&device=c&network=x&matchtype=&adpos=largenumber&locationid=9192245&creative=&targetid=&campaignid=21161059808&awsearchcpc=&gclsrc=aw.ds&gad_source=1&gad_campaignid=21154165899&gbraid=0AAAAAD_RQYnKvY2u_vUYAW2TCMKYAN1ub&gclid=Cj0KCQjwt8zABhDKARIsAHXuD7avziYe74c5yv6lQS5Lhwuro1XrlWELYA8AXd9po5HuOE8ZsT0PhiUaAqYYEALw_wcB it’s a little more plastic than the Traktor ones. / Instead of faders, you could use rotary knobs. DJ tech tools has some stuff, Akai does. also found some neat boutique controllers on tindie, (https://www.tindie.com/browse/midi/) ( I use the APC Mini on my full board. 4x6 loops in the top right corner, fx on the left side, and the far side buttons to open / close menus. )
It’s simple, you need to open the Native instrument software AND the midi map in DJay ai.
Then on the controller, flip to “midi mode”
Shift + browse I believe , is have to check. But then you have access to the full controller. Save the profile in both platforms!
Cool note- even the “shift” button works for extra functions and pages.
I’m the native software, be sure to know the parameters of the button or knob. You can also change and mod the led lights, change from toggle to switch or momentary. If you don’t like it, you can always change it
Oh- and yes it works on OS. I’ve done it.
@thedrummingdj
Good stuff, thanks! We’re on the same page. I fell in love with the idea of faders. I’m currently using the Akai lpd8 with rotary knobs as my stems. It works perfectly with both iPad and Mac, but since it would have been cool to have 4 faders and 16 pads, 8 pads for each deck, the f1 stood out.
I also looked into creating my own custom midi with the build your own solutions, but you pay for it $$$.
Mk2 is a beast and far more pads than I require but I may have to do it.
Thanks for your input
Excellent. Thanks for the input
Super helpful
