I have an NI Traktor Kontrol S2 Mk2 controller and purchased the full version of Djay Pro.
I used the demo to try out the software, and used a downloaded MIDI-map for my controller. I put the MIDI mapping file in to the Djay Pro Demo MIDI-map folder and i was able to use my controller perfectly.
I purchased the full version now, and i am not able to use the same midi mapping file because Windows won’t let me put the file in the folder because of authorization issues. I faced the same issues with the demo, but was able to fix it there. With the full version i made the same steps as i did with the demo to fix my authorization issues but it doesnt work…
I dont want to map my entire controller into the software when i can just use the same file i used before.
Can someone tell me how to fix my problem?
