Traktor S4 Mapping Issue - "Select Next Track"
I’ve tried to map my “Browse” knob on the Traktor S4 so that I can sift through my music library using the controller. To do so, I’ve used the “Select Next Track” mapping option. Unfortunately, it doesn’t STOP moving down the playlist once its engaged. The selector continuously highlights the next track until it ends up at the bottom of the playlist – all from twisting the knob one time.
What can I do so that the selector moves ONE place down and then STOPS until I twist the knob again?
thank you for your post.
Please try to map “Music Library” - “Move Library Selection (Rotary)”, I attached a screenshot.
If this isn’t helping please don’t hesitate to contact us via support@algoriddim.com.
Thank you and
keep it up,
bonjours , je voudrais qu on m aide , pour configurer le traktor s4 avc djay pro , , jai trouver la configuration que pour le s2 , merci
