Interesting workaround. Thanks for sharing @7nz
Traktor Z1 MK2 AJAY - 25 March 26 v3.djayMidiMapping (23.9 KB)
Hi All, newish to ADJ, been nerding out quite deeply on midi mapping over the past month. I have managed to create a very usable Kontrol Z1 Mk 2 mapping, complete with working level meters, that respond properly to the music level (so you can adjust gains and level properly), not just show where the volume slider is at. Hope someone finds it helpful. It’s also intuitively mapped with loop, cue and play functionality. Let me know if you have any questions.
Nice! Thanks for sharing @ajayabc
Traktor Z1 MK2 AJAY - 28 March 26 v4.djayMidiMapping (23.9 KB)
Updated version - the buttons labelled 3 and 4 now modify the tempo.
Great! Thanks for the update @ajayabc
Sound card is class compliant and works anyway
Thanks for sharing @marsu
ajayabc you’re great! I found a small error in the xml code mapping that creates a slight anomaly in the led activity. Basically, the part that activates the first led of the second channel vumeter (cc21 - channel 2 -19) says “turntable1.monoMeter” instead it should be “turntable2.monoMeter”. Anyway, great job!
Good catch @giu_gi
Oh nice! glad you like it. Thanks for picking up that error. I have actually made a new version of the mapping, that introduces some new functionality. I’ll document the functionality and upload it soon.
Looking forward to seeing your next update @ajayabc. Keep up the great work!
This is the best Z1 mk2 mapping I found, great job. It’s really awesome to see the vu meters working. There’s a small glitch: the left vu meter seems to “leak” in the right one, the top led of the right vu meter follows what the left vu meter does instead of following the music in the right track.. it’s definitely not a major issue, I’ve adopted this mapping immediately
thanks a lot!!!
