Transfer Hot Cue to another device - Android
Greetings.
I have a question. I’d like to know if there’s a way to transfer everything I’ve done on one device, such as the breakpoints, from one Android device to another. I need to change the device, and it seems like I’m going to lose everything I’ve done on my old device.
Hi @Enrique_Fagundez, unfortunately, there is no way on Android to backup and restore your djay specific data. Your best option is to do a full system backup from you existing Android device and a system restore on your new Android device. I hope that helps!
Feature request!
Lots of hours go into marking songs with que points.
What is the file extension containing this data or file path on Android?
Some apps offer to export it automatically. Backups are important. There must be a way to solve this.
Hi @sandfish, welcome to the Community! Thanks for the input. I have changed this topic from a question to a suggestion so you can upvote for this feature at the top left of the page. I hope that helps!
Saludos y Gracias.
Hice la transferencia de la allicacion de Djay, a traves de varias aplicaciones de transferencias entre dispositivos android, Y solo me transfiere el app, pero Todos los puntos de corte, Los analisis de BPM, se pierden, no he encontrado manera, es decir, Se pierde todo y hay que establecer todo de nuevo!!!
Greetings and thanks.
I transferred the Djay app using several Android transfer apps. It only transferred the app, but all the breakpoints and BPM analysis were lost. I haven’t found a way to do this. I mean, everything is lost, and I have to reset everything!
Thanks for the follow up @Enrique_Fagundez. Sorry to hear that did not work. I have passed this onto our engineering team to see if there are any other options. In the meantime, I have changed this topic from a Question to a Suggestion. Please use the blue Vote button at the top left of this page so we can gauge user demand for adding this feature to djay on Android. Thanks!
