hi, how do i manually transfer my library and data (cue, loop, grids,tags,) on my mac to iphone without using itunes? For example if i don’t want to use mac anymore , i want all my music and data transfer to iphone.
Thanks.
Thanks.
Hey @Donn
Where did your music come from on your Mac?
I have one folder that contains all my songs that’s located in the mac’s Music Folder. (I don’t use Itunes)
The least complicated way I can figure out how to get that in there. If you didn’t buy the music through iTunes it just simply use the Mac and sync your device to the Mac. I promise you it is the easiest way.
Thanks for the info! It might be too crazy for me since I don’t want to sync everything from the iphone to mac and vise versa. Just want to transfer everything from Djay pro only. (mac to iphone.)
