Transferring playlists w/cue points from Rekordbox to Djay Pro
  • Device model: 2023 Mac Studio Apple M2 Max
  • Version of operating system: Mac OS Sonoma 14.6.1
  • Version of djay: 5.2.6
  • Hardware/controllers used: Pioneer FLX4
Is there a way, possibly through a service similar to Lexicon DJ where playlists can be transferred from Rekordbox into Djay Pro?
I need the ability to transfer playlists from Rekordbox to Djay Pro with cue points for both local music files as well as files in Tidal. Having to rebuild all of these playlists in Djay is going to be a nightmare resulting in many, many hours/days/weeks of work.
Hi @ameratom, since you are on macOS, you might want to check out DJ Conversion Utility. I believe they offer two applications for this task. One for local music and one for streaming music.
That’s right!
This tool works great for these kind of conversions. You should check it out.
DJCU Is it great suggestion, it’s what I have purchased and used. Many others are a monthly fee to use the service, but DJ conversion utility (DJCU) is a one-time purchase, And well worth the money as the creator of the program is very active on YouTube and different platforms
Yes, transferring Rekordbox playlists with cue points to Djay Pro is possible using tools like DJ Conversion Utility on macOS. They provide separate apps for local files and streaming services like Tidal, preserving both track structure and cue data. There are other tools like MusConv can be useful if you’re managing playlists across streaming platforms, helping consolidate your library before using conversion tools. This approach can save significant time and ensure a smoother transition between DJ platforms.
