Transition files sorting options
YOUR SUGGESTION:
I like how the software analyses transition files automatically, but I often still have to manually add beat markers to reset it for sorting purposes. I prefer files to be sorted by the BPM they start at, not the main BPM of the track.
I’ve noticed many downloaded transition tracks get missed because the software sorts them by the track’s overall BPM rather than the starting BPM. This makes them hard to find in a live set.
For example, if I’m playing in the 80 BPM range and have a strong transition track that starts at 80 and moves up to 120 BPM, I’ll usually miss it while mixing because I sort my playlists by BPM and the software lists that track in the 120 BPM range instead. Please can we add an option that allows these types of files to be sorted by either the starting BPM or the main BPM, so they can be surfaced correctly during a live set.
3 posts were merged into an existing topic: Display intro BPM instead of outro BPM in library
Merged with existing topic: Display intro BPM instead of outro BPM in library
