NOTE: searched through topics.
Djay v. 5.2.6.
iPhone 14 Pro
iOS v 18.11
Mix now has options for Neural Mix.
Can you implement the same options for Automix?
Hi @LaidbackFred, I’m pretty sure if you enable Crossfader FX while in Automix, it will use what you have selected for CFX instead of what you have selected in Automix.
Yes, I can confirm this - when it is ON, Crossfader FX will override the Automix transitions.
Doesn’t work on its own,
When End cue arrives, djay will use Automix selection.
Only works if the user triggers mix using mix now.
Yeah, I just tested it again now. If you’re in Automix and press the Mix Now button it will use the CFX instead of the Automix transition type. If you let it transition on it’s own it switched to the Automix type. I will pass your suggestion onto the team to add the CFX transitions to the Automix transitions. Thanks!
