Transition MIDI mapping
All transition mix (Automix menu) are not mappable in MIDI.
Seems to have some others in MIDI mode (like the brake & reverse) and missing the Riser, Dissolve and some other Mix transition form from the preference menu.
Thanks for the new mapping options with all Mix transition option >> would be nice to have a toggle transition button in the frontend and MIDI options :slight_smile:
Hey DJ_lion,
Thanks for bringing this up to our attention. We’re actually working on improving some aspects of the MIDI interface. Your feedback is very important to us.
I’ve escalated this to our developers. We’ll keep you posted here regarding the status of this.
I like to have Midi buttons to start/stop auto mix and other to skip to next auto mix track.
Hey guys,
It’s possible to trigger a specific transition by having a MIDI button mapped to “Set X Transition” (not all transitions types are available) and a second MIDI action mapped to “Transition Left/Right”.
Let me know if that helps @DJ_lion.
@karimrg, I’ll check these two Automix functions internally and I’ll get back to you soon with more information.
Cheers, G
