when i have saved loops 1-8, and i trigger a reloop on one of them, it seems to be off by minus one the first time i trigger it. so if i trigger 2, it reloops #1 (although it will actually loop #2 once it gets to that section of the track). I’ve attached a screen recording showing this, triggering 1 / 2 / 3 and you’ll see the behavior
is anyone experiencing this issue? it’s turning out to be a huge issue. To recreate:
- set up saved loops one through 8
- use the “saved loop reloop X” trigger (can recreate issue in either midi control or directly though interface)
- most of the time (not all…) it will trigger the start of loop X minus 1, although the loop is actually still set to X
(NOTE - triggering loop 1 always works, because there is no X minus 1)
