Device model (e.g. 2020 iPad Air 4th Gen):
Version of operating system (e.g. macOS 14.4.1):
Version of djay (e.g. 5.1.2):
Hardware/controllers used (e.g. Reloop Mixon 8 Pro):
Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
Hello, I’m having trouble pre-listening to tracks I downloaded locally. Sometimes I can’t hear them, sometimes I just hear the bass, and sometimes I can hear the entire thing. However, if I use Spotify as the source, I have no problems. Can you help me? The tracks I downloaded are in unprotected MP3 format.
Hi @Dens, When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”.
Hardware Firmware Version:
Can you please share screenshots of your Automix Settings?
I suspect you have enabled a Neural Mix transition type. Please note that pre-cueing is not supported for NM transition types.
Thanks, you were right. I had automatic transitions set, including NeuralMix. Once I turned off automatic, everything started working perfectly.
Thanks again, I was going crazy…
