I have 16k songs in a folder structure mounted on a USB drive. I have added that folder using “add folder”. But search only seems to work within each sub folder. How can I search for a song without having to search each sub folder?
Hi guys,
Thank you for your post.
Can you tell us the formating of your external hard drive?
Cheers,Lukas E.
Have you got an answer for this? Did you or they solve this?
Its ntfs
