Try this to get Djay Pro running again on Windows 10 without crashing during splash screen
It helped me, hopefully it helps you too.
Check if your c:\users\Default folder is hidden. If so, unhide it.
After I did that, Djay Pro worked like a charm again.
I really hope it works for you too!
Cheers
Ihab
