Connect the Vestax Typhoon controller to my Macbook Pro via the USB port. Open up Djay for Mac. Go to the MIDI pull down menu - see the Typhoon Controller listed in the first menu entry with: configure typhoon controller - click on that, which opens the midi configuration box - I see typhoon controller in the MIDi configuration list - open the Advanced control options ( as suggested in previous posts/questions) the MIDI out box can’t be checked as it’s not highlighted, click the done button - and zero interface! Need some direction, suggestions, advice. Does the Vestax Typhoon controller actually work with Djay for Mac?
Hi Brendan,
Did you map the buttons/ctrls? Try the following:
- push a button on your controller
- select a corresponding action from the drop-down menu
What is your Devices setup (djay -> Preferences -> Devices)?
Hi Warren,
Many thanks - that helped…have been busily mapping out all the buttons and faders…which mainly correspond - don’t seem to get any response when I turn the main output knob (doesn’t trigger anything in the pull down menu) - now have a bizarre problem that all my files when loaded in their respective turntables are horribly, digitally distorted as I play them. Do you have any idea what’s causing this?
Thought i 'd sorted out my problem with this controller!
Thanks Brendan
