Can you use Turntable+controller on djay pro mac. So I was looking on our local “ebay” called tori.fi and I saw better deal then the 400€ controller what was in my mind. The setup What was there was 2 turntables for 1€ and 40€ for small controller, and I was thinking that is it pausible to connect those turntables with timecode vinyls to that controller and controller to my Mac djay pro and use it to mix? Thanks.
we are sorry to tell you but we are not supporting timecode vinyl.
You can use an external mixer for djay Pro and connect your turntable right to the mixer, as a workaround.
