Can somebody make a tutorial on how to scratch using IDJ pro,? plus what are the things to be enable in djay app using IDJ pro…I’d appreciate it big time if somebody would.
Thanks in advance,
Bre3z
Thanks in advance,
Bre3z
Hi Bre3z,
Open djay’s settings -> MIDI and make sure that:
Then you can pitch bend using the jogwheels.
Oh so the -jog pitch bend mode is suppose to be off? Mine is on, so I guess I should turn that off… Anyways what’s does it do if its on?
Thanks,
Bre3z
