Type Ahead vs Search Folder — they serve different purposes
I’d like to request a standard feature that’s common in Finder-style windows, usually called “Type Ahead.” Serato calls their version “Playback Keys Use Shift,” and VirtualDJ calls theirs browserSearchByFirstLetter.
I want to point out that this is completely different from folder/playlist search, and the two get conflated:
  • Type Ahead — instantly locates the playlist or column entry you want. You already know the name you’re looking for, so you type the first letter(s) and it jumps straight there. This is a 1-step process: type → land on it. It’s the fastest, real-time way to jump straight to the crate/playlist you want — nothing quicker. Whatever window is in focus or whichever column is selected determines what gets matched — it works this way both for locating a playlist and for jumping to entries inside a playlist itself. Both Serato and VirtualDJ already have this.
  • Search Folder (VirtualDJ’s term) / crate search — completely different: this searches across multiple crates/playlists at once and gives you a list of matches that contain the text you typed, then you pick which one you want. This is a 4-step process: 1) search, 2) look at results, 3) click, 4) choose the result — versus Type Ahead’s single step.
These solve entirely different problems and are used in completely different workflows. They are not interchangeable. Please consider implementing both rather than treating a global search box as a replacement for native type-ahead navigation. Also please notice these are very different from Favorites bank workflow as well.
Thank you!
Hi @Donn, thanks for the suggestion! I’ll share this with our devs for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
