Now you can’t see info about others tracks.
Because to DJing is not only to plugin your equipment you have to touch screen also for more creativity.
Keep up the good work team.
My opinion is like long time user is we need some improvements like resizing the app like (Luma Fusion), remote control like (Filmic pro remote), more options for customisation playlists, change UI experience, ability to record and use some parts from song to used in sampler and pads for more creativity like this function in AlfaTheta GRV6.
Hi @Digital_Jedi, I just received a follow up with the dev team.
“Could you please provide further detail on “change UI experience”. We understand the request about waveforms in the library and better preview. What specifically would you like to see in the other areas for which you showed screenshots?”
Where the playlists column is (on the left) you can add a “Waveform” button.
If you select it, the Waveform of the track will be displayed instead of the playlists column. Like on the screenshots above.
Additional fields for tracks have been already written here on the forum many times: rating, comment, etc.
So that the user can choose displaying of necessary fields and width of these fields.
Regarding improvement of pre-listening.
I have already asked to make improvement in this direction. But it was more about the phone version.
If you use horizontal mode on the phone, you can place the CA to the left of the track covers. With a width of 1/3 of the total length.
If you use vertical mode on the phone, then… it’s hard to come up with something interesting and convenient… I would suggest listening by double tap on the screen, but right now that option loads the track into the deck, which is also convenient. We all need to think… what can the developers come up with?
