UI Suggestion for djay Pro Mode (iPhone)
YOUR SUGGESTION:
Dear community and programmer of djay for the iphone.
In my workflow, I almost always use the Pro view. Sometimes the waveforms are more important to me and I turn off the virtual deck view.
But if I only use the waveform view, the current bPM range is unfortunately not displayed in the Pro view in conjunction with a controller.
For me, this would be important, because I don’t always want to open the tempo area first to choose the tempo-range.
It would be nice if you could also get the bpm-range displayed in the Pro view without the virtual decks.
Dear algoriddim team, can you please make this possible?
Greetings from Rheinland-Pfalz
Hi @Martin_Baldauf, can you please share a marked up screenshot to clarify your suggestion? Thanks!
Below is a screenshot with a controller connected and djay in Hardware Mode
This is what it looks like with a controller connected and djay in Pro Mode instead of Hardware Mode
In both cases the BPM is visible.
