Unable to login Tidal with Google
YOUR QUESTION: Logging into Tidal with Google is greyed out, this doesn’t happen on my mac when linking Tidal to djay. I’ve read a forced iphone restart can help by clearing cookies or something but it didn’t work.
  • Device model (e.g. 2020 iPad Air 4th Gen): iPhone 17
  • Version of operating system (e.g. macOS 14.4.1): Latest iOS
  • Version of djay (e.g. 5.1.2): 5.5.2
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Not applicable
  • Hardware firmware version (e.g. 1.0.1): Not applicable
Hi @sdajlkajlkwl, are you using a VPN on your iOS device?
I have same issue on macOS
Hi @Artur, welcome to the Community! Can you please share full details about your setup?
Are you using a VPN?
No VPN or private relay
Thanks for that @sdajlkajlkwl. We are still unable to reproduce this.
@Slak_Jaw thank you for the reply. I just realized that I found this forum by Google search and it isn’t Tidal’s forum.
In fact I don’t use djay. I cannot log in to tidal.com itself with Google. So I guess the issue on Tidal’s side.
Oh I see. Thanks for confirming @Artur
Hi again @sdajlkajlkwl, sorry for the delayed reply. Our engineering team has confirmed that this is a known issue on Tidal’s side. Unfortunately, you will need to sign in with a different login method or contact Tidal support for further assistance. Sorry I couldn’t be of more help.
Still having the same issue in February 2026…
Hi @dvalex, welcome to the Community! Please try logging out of all Tidal stand alone apps and browsers. Reboot your device, launch djay and only log into Tidal within djay. I hope that helps!
Hi! This worked, thank you!
You’re welcome @dvalex
