unaffected pitch fader even after syncing 100 bpm to a 130 bpm song
I love fine pitch mixing on my pitch fader, but as I’m open format and I do a lot of mashups, I have to keep my pitch fader at 25%. So what if like sdj adj instead made it to where the pitch does not affect my pitch fader jump up, and I can still have my pitch fader at 8% or whatever the preference of that DJ even after the pitch fader is moved
Hi @DjCrossFade1200, are you talking about a Relative Pitch Fader setting? Please rephrase and clarify your suggestion. Thanks!
so lets say i have a 100 bpm hip hop track and i sync it to a house track at 130 in sdj it will not effect my physical pitch control and adjust the song speed like if the hip hop track was sitting at 130 naturally . my physical pitch is untouched to i can do fine adjustments with it
Since this sounds repeatable, can you please capture and share a short video of the issue to help clarify what’s happening? Thanks!
o sry been out djing gigs im going to get to it as soon as i can
Sounds good @DjCrossFade1200. I’ll keep this topic open then.
