Hey all,
I have the frustrating problem that some tracks are showing as not available in the playlist.
So then I try searching for them on my computer in the ‘browse’ section of DJ Pro 2. When I find the track… I’m able to drag them onto one of the decks and it plays just fine.
However, if I remove the ‘missing’ file from the playlist and re-add it into the playlist, it immediately shows up as unavailable again. It’s as though once it’s marked unavailable, DJ Pro 2 always thinks that track is unavailable forever and ever!
A similar problem also occurs with Spotify tracks in Dj Pro 2 playlists - where if I then go on to buy the Spotify track as an MP3 and add it to a playlist (because I want to play it offline in sets) - DJ Pro 2 still thinks it’s a Spotify track! Which means I’m not able to play it offline in sets, at least not from the playlist
Is there a solution to this problem please? It’s causing me no end of trouble!
