Understanding Sync / Sync Master / Tempo Reset [Win / DVS]
Thanks for the feedback @skymakai . I recommend that you create a separate suggestion topic for a Sync Master / Tempo Master Indicator. Then you and others can upvote it and I can forward this to our devs for consideration.
Done! Allow Users to Disable Automatic Features
Thanks @skymakai
